| Author |
Message |
fletch696
Post subject: blitz traction Posted: Wed Feb 15, 2012 9:15 pm |
I'm running a CC SV2 esc and a 5700 KV motor on 3s 15 pinion 88 spur, and I can't get it to hook up and run strait at full throttle... any tips?
Brian_BigSquidRC
Post subject: Re: blitz traction Posted: Wed Feb 15, 2012 9:53 pm |
| Site Admin |
Joined: Sun Aug 22, 2004 10:01 pm Posts: 1272 Location: Near Chicago
Dirt? Street?
What are you running on. 3S in a blitz is gonna be pretty gnarly since it's a light truck. What tires are you using?
_________________ Brian(at)BigSquidRC.com http://www.BigSquidRC.com
fletch696
Post subject: Re: blitz traction Posted: Wed Feb 15, 2012 10:08 pm |
dirt and street mostly street. stock tires.
Brian_BigSquidRC
Post subject: Re: blitz traction Posted: Wed Feb 15, 2012 10:13 pm |
| Site Admin |
Stocks are pretty good on the street.. they make a cool squeal sounds.
We dig the Pro-line Trenchers as good all around tires. They hook up in a lot of places, and pretty durable.. you won't wear them out too quick.
fletch696
Post subject: Re: blitz traction Posted: Thu Feb 16, 2012 6:00 am |
I was thinking of trying heaver fluid in the diff. currently running 30k. think that will help?
tmohr
Post subject: Re: blitz traction Posted: Thu Feb 16, 2012 5:26 pm |
Joined: Thu May 03, 2007 12:41 pm Posts: 48 Location: St Louis MO
3S 5700 on a Blitz is going to be pretty hard to put down on dirt except on blue groove... so I am just going to post a paved set-up... this is for going fast straight with a Blitz, not for road course racing or off roading....
1. Pro Line Street Fighters Front and Rear M2 2. AKA Blue Med Inserts rear, AKA Black Hard Front 3. Paragon Rear Tires only, most likely you'll have to go to Grand Motorsports Light Traction compound 4. Lock Diff with JB Weld 5. Neg 2 degrees rear camber 6. Zero front camber 7. 4 degrees rear toe 8. Zero front toe 9. CA glue Front Outer rib 10. Turn steering endpoints down as far as possible while leaving enough to turn the way you like 11. Battery all the way to the rear 12. Slipper- less than 1 foot of slip but not locked 13. Arms level front 14. Bones slightly below level
_________________ Castle Creations MaxAmps Batteries http://www.BigSquidRC.comGrand Motorsports
